-   -   finishing my basement Questions (http://www.diychatroom.com/f19/finishing-my-basement-questions-12382/)
handyman1355 10-14-2007 06:53 PM
Hello, I have been thinking of finishing my basement and would like some advice on sealing for moisture. The basement is a block foundation with concrete floors, it stays pretty dry except around an outside entrance door, but would like to seal all of the block to ensure no future problems. Thanks for your help.
kemerick 10-17-2007 10:47 PM
Try this stuff: UGL - DrylokŪ Latex Masonry Waterproofer
http://www.lowes.com/lowes/lkn?actio...515&lpage=none
I have seen it at Lowes and Home Depot for well over a decade... it must work well... you would assume.
AtlanticWBConst. 10-18-2007 05:28 AM
Please bear in mind that the first course of action with solving moisture/water/dampness in regards to basements is: Keeping the water away from the foundation or the areas where you are seeing moisture, or moisture seepage. Make sure that water run-off (drainage) is properly taken care of first around your outside entrance door. Example: Grade should be sloped away from the area. Downspouts should not be draining into or near that entrance area. There should be minimal shrubbery to allow the outside location to dryout properly after rain, etc.
Bear in mind that waterproofing compounds (like Drylok) work against most basic concrete moisture, but not against hydrostatic pressure (pressurized drain water seeking a way to get into the foundation). This may...or may not....be your situation, but it is something to consider.
link example: http://www.misterfixit.com/wetbase.htm
jscholl411 10-18-2007 08:04 AM
Maybe testing in areas of the slab would be a good idea? take a 2x2 sheet of poly and tape it down to the slab for about 48 hours.(make sure it is sealed to the floor) If you get moisture then you might have to seal the floor. If not then might already have a moisture barrier underneath, then the only thing you need to worry about is the outside entrance.
MinConst 10-18-2007 09:03 PM
Atlantic says it well stop the water from coming in at the source. DryLok is a temporary fix at best.
