Finishing My Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 11:54 AM   #1
Finishing my Basement
Hello,
Since this is my first post let me first say a big hello from Ontario, Canada.
I've just started work on finishing my basement and I have a plan on how I'm going to do it. Being that I'm not a professional I want to make sure I'm doing everything right as I want to avoid costly repairs to my house so I have a question before I get to carried away.
The insulation (polytarp wrap R8) in my basement only goes half way down the basement walls now and I realize that this is going to have to be replaced with a min of a R12. I want to remove it now so I can put my framing in but the problem is it's very cold where I live right now and I'm not to sure how much removing it will effect the rest of my house. It's probably going to be a few weeks before I get all the framing done, electrical roughed in, and the insulation in. Will a few weeks of the insulation removed from the basement cause any harm to the rest of my house? Moisture damage? Damaged caused by sub-zero temperature?
Scott
sensor330 is offline   Reply With Quote
Old 12-21-2010, 05:42 PM   #2
No, just may run up your heat bill. But you stated it only goes half way down on the wall, meaning the other half is bare? If so, youre not gaining much R value anyways. Take it out. Stud, run electric, plumbing, insulate, drywall.
klaus135 is offline   Reply With Quote
Old 12-21-2010, 06:00 PM   #3
Experienced
Jackofall1's Avatar
For years when running heat loss summaries concrete walls below grade were not considered, as the actual loss was so insignificant.
So go ahead a take that stuff down, I doubt you see much of a difference, that is if the majority of your basement is below grade.
Old 12-21-2010, 07:42 PM   #4
Rewards Points: 1,418
Nowadays, many cities' building codes require insulating the concrete foundation wall all the way down to the floor. When installing new insulation, leave out (or cut holes in) the vapor barrier just under the drywall or paneling unless you are sure that the outside of the foundation does not have a waterproofing coating.
More on finishing up a basement: http://www.co%43kam.com/theater.htm
Old 12-21-2010, 08:40 PM   #5
Registered User
Rewards Points: 4,924
http://www.quadlock.com/technical_li...Insulation.pdf
Gary
Old 12-21-2010, 09:23 PM   #6
MJW
I would also recommend using an extruded foam of some type. Thermax usually works best. Put that on the walls (sizing depending on Rvalue required) and then build walls outside of that. Then you will probably only have one day with exposed walls to the cold. The quadlock sounds nice, but you will lose quite a bit of room being it is 4 1/2" thick. I only have knowledge of it through GBR's link though. Never seen it before.
MJW is offline   Reply With Quote
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Finishing basement - insulation problem? Gooter Building & Construction 6 08-24-2009 09:23 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 09:13 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 01:30 PM
