Old 03-28-2012, 03:49 PM   #1
Finishing an exterior wall that extends beyond the wall above.
I'll try my best to describe this dilemma. I am finishing an area under a previously added addition. Because the addition is supported by posts, I can not pour a stem wall directly below the addition's exterior wall and maintain a continuous above grade wall. My solution, after consultation with a contractor, is to pour a footing and stem wall that extends 6" above grade that is just outside of the existing perimeter. The stud wall will have to be tied into the above framing. Non of this is an issue. The issue is with how I finish this because the lower non-load bearing wall will sit six inches beyond the upper wall. The house is vinyl siding. Do siding manufacturers make a z channel any larger than 6". Any other ideas?
RockingM82 is offline   Reply With Quote
Old 03-28-2012, 04:21 PM   #2
Framing Contractor
A picture would be helpful. Can you build a small roof across that to create a separation?
This will turn an eyesore into a nice feature.
sixeightten is offline   Reply With Quote
Old 03-28-2012, 05:49 PM   #3
Haverhill Trade 1965
Is there a siding and roofing company in your area? If so they might be able or willing to bend something for you. The ones near me have a brake and coil stock to use for a small fee plus materials. Make a cardboard pattern, or a cross section drawing for a pattern. there may even be a color that looks good, or you can paint it yourself to match.
Duckweather is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Finishing my basement: wall insulation? 1jumper Insulation 6 09-15-2011 11:29 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General Discussion 5 02-02-2011 09:39 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
