Finishing Edge Of Mirror - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 08:59 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Finishing edge of mirror
Hello y'all
I am cutting some mirror and was wondering how I would finish off the edges so that I won't cut myself when handling. I don't want a professional buffed edge, all I want is to make sure that if I touch the mirror's edge I don't want to slice my hand.....
Thanks for your help.
yummy mummy is offline   Reply With Quote
Old 12-01-2011, 09:44 AM   #2
43 years in construction
Arkitexas's Avatar
For a truly safe handling you can grind the edge with a handheld belt sander (1" to 4"). In our shop, to achieve a "consumer handling edge", we grind a small 45 degree bevel at the edge of each face (1/16") using use two belts, a 180 grit and a 120 grit. Lay the glass flat on a table with the edge just overhanging. Start with the 120 grit coarse belt and grind so that the belt runs from the top smooth face and exits on the cut face. Don't get overly aggressive with the sanding pressure. Follow up with the 180 grit belt. Turn the glass over and repeat from the other face. I've seen this attempted using a hand sanding block but it is slow and can still leave sharp edges. The work moves faster and easier with a diamond faced hand grinder. If that's too much money or work, wear heavy gloves.
Rick
Arkitexas is offline   Reply With Quote
Old 12-01-2011, 09:55 PM   #3
Thanks very much Arkitexas.
I don't have a belt sander. I guess I can try with sandpaper and good gloves.
I am not concerned with doing it quickly, as long as I can get it done using sandpaper, then I am happy.
Old 12-02-2011, 08:13 AM   #4
Rewards Points: 5,336
Using any sander will do the job, just more slowly. An orbital sander will do the job as well.
Ron
B. Franklin 1759
Old 12-02-2011, 08:40 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,708
Ayuh,... If yer not in a hurry,...
I've had reasonable results using emery cloth, or a sharpening stone...
'n Yes, good leather gloves are Mandatory...
Old 12-02-2011, 10:47 PM   #6
Thanks all for your help. I am going to get myself some sandpaper and do it.
BTW I am trying to cover a wood coffee table, that has a really nice shape, with mirror. I have gone to a glass shop and it would cost too much to have it cut by them. I want to cut the legs myself and then have them do the top with 1/4 inch mirror with bevelled edge.
Old 12-02-2011, 10:57 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hi Yum,
Hey, just be sure your mirror isn't made of safety glass first. Assuming you are cutting something you already have around the house. You won't be able to field-cut safety glass. The minute you try it will shatter like a windshield but nothing will hold it together.
XXX
Old 12-04-2011, 11:18 PM   #8
Hi Bud, hope you are keeping well.
I tried it out just to see, given your suggestion about safety glass, and it is not safety glass. It did cut.
Going to cut the leg part this week.
Thanks so much for your help.
The Following User Says Thank You to yummy mummy For This Useful Post:
Bud Cline (12-05-2011)
Old 01-14-2012, 02:35 PM   #9
Get a Aluminum oxide sanding belt from a hardware store or glass shop, cut it and clamp it to a piece of 2x4 you only need to "seam" it as we say in the trade. slide it over the edge at an angle as you hold it at a 45 degree angle to the glass/mirror. a few strokes on all edges will make it safer for you. Also I rub the corners to to round them a bit.
Bobby
Amazingglazier is offline   Reply With Quote
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Receptacle under mirror quincy Electrical 5 03-24-2011 01:40 PM
large bathroom mirror DK75 Remodeling 4 04-18-2008 05:27 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General DIY Discussions 18 08-10-2007 10:04 AM
