Finishing Drywall And Masonry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 05:43 PM   #1
finishing drywall and masonry
Hello All,
I was wondering if you guys had any suggestions about a problem I am having.
I am finishing my basement I have drywall up on all four walls.
My problem is the wall coming down the stairs I wanna just let it masonry.
I will have on corner that is drywall on one side and masonry on the other.
How do I finish this corner?
Is their a special corner bead I can use?
I plan on painting the walls the same color.
Thanks Jake
Bigin429 is offline   Reply With Quote
Old 08-08-2012, 06:06 PM   #2
Rewards Points: 14,010
Not sure how you can have four walls finished with drywall and and still have an exposed wall?
It's called and end cap. http://www.pittconindustries.com/index.php/softforms
Still will have to use some paintable caulking at the seam because a masonry wall is almost never flat.
And you going to need two totaly differant paints to do the two differant walls.
How did you "attach" the drywall you have now?
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Tiny masonry bits? / OOKS and plaster walls cerfsud Carpentry 5 12-10-2011 04:22 PM
tapcon or masonry nail? Aloha1 Building & Construction 3 09-19-2011 09:02 PM
Fastening grab bar to tiled drywall with minimal clearance behind pdinnen Building & Construction 4 01-29-2011 05:39 PM
Help with drywall to masonry wall kc5oh Building & Construction 5 03-31-2008 09:14 PM
