-   -   finishing drywall and masonry (http://www.diychatroom.com/f19/finishing-drywall-masonry-153086/)
Bigin429 08-08-2012 05:43 PM
Hello All,
I was wondering if you guys had any suggestions about a problem I am having.
I am finishing my basement I have drywall up on all four walls.
My problem is the wall coming down the stairs I wanna just let it masonry.
I will have on corner that is drywall on one side and masonry on the other.
How do I finish this corner?
Is their a special corner bead I can use?
I plan on painting the walls the same color.
Thanks Jake
joecaption 08-08-2012 06:06 PM
Not sure how you can have four walls finished with drywall and and still have an exposed wall?
It's called and end cap. http://www.pittconindustries.com/index.php/softforms
Still will have to use some paintable caulking at the seam because a masonry wall is almost never flat.
And you going to need two totaly differant paints to do the two differant walls.
How did you "attach" the drywall you have now?
