Finishing Basement Walls And Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 10:47 PM   #1
finishing basement walls and floor
I want to put 1" XPS on floor than 5/8" or 3/4" T&G OSB. Walls will be 2" XPS all seams taped with tyvek tape including floor/wall and gaps filled with spray foam. 2"x4" studs framed against XPS no space and filled with unfaced fiberglass insulation and finished with 1/2" drywall.
1.Must the OSB be Pressure treated or AdvanTech or can I use regular T&G OSB?
2.Should the floor be installed first than the walls?
3.Does the bottom plate need to be P.T. when installed on XPS?
4.Do I need a thermal/capillary break between the bottom plate when installed on XPS. If so Suggestions.
5.Can I install the wall first on top of a ripped length of XPS say 6" wide then tape seams when I do the floor?
6. The side wall will need supports about every 3' from the sill plate to the joist for the top plate. Will those supports need to be pressure treated as they will sit on the foundation wall? gasket needed under plate?
7. After filling the rim joist with 2" XPS and sealing seams can I fill the rest of the cavity with unfaced insulation?
Thanks for your thoughts,
Micky
micky is offline   Reply With Quote
Old 02-22-2011, 11:47 PM   #2
Rewards Points: 410
welcome
http://www.buildingscience.com/searc...eText=basement
this will get you started if the link doesn't work highlight/copy/paste
lots of info available using the search on this site
Just going to order roxul tonight through Lowes ( they finally carry it special
order ) for covering the xps rim joist but glass is acceptable.
High Gear is offline   Reply With Quote
Old 02-22-2011, 11:47 PM   #3
Rewards Points: 956
not really related but where do you go buy xps boards/sheets?
federer is offline   Reply With Quote
Old 02-23-2011, 12:15 AM   #4
Rewards Points: 410
Home Depot , Menards , Lowes ect.
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Best way to insulate basement walls / floor? benze Building & Construction 1 09-07-2010 08:17 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
