Finished Basment Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 08:14 PM   #1
finished basment questions
starting basement renovations, I had cheap wainscoting on basement walls, pull that all off along with the bottom 4ft of sheetrock due to it being glued to sheetrock. With the framing exposed, the basement foundation walls were framed with 1x2" furring strips and nothing running along bottom of wall. 1/2" foam in between strips. Some mold on furring strips, Best i can tell they aren't treated wood. Something doesn't seem right here. House was built in 1983.
I live in MN, am I better off pulling down the walls along foundation and reframing the walls with treated 2x4's and R-11 inbetween?
Greenhead12 is offline   Reply With Quote
Old 10-21-2011, 09:43 AM   #2
I'm just Joe homeowner, I have a new construction house that I'm working on it's basement as well. I can tell you in new homes, they put down pressure treated bottom plate, with 2x4 walls and R13 insulation. R13 is required via code here in Fargo over R11. Also you will need about an inch of airspace between the wall and the concrete foundation. You can't have fiberglass touching the concrete. Styrofoam can be glued to the wall.
live4spd is offline   Reply With Quote
Old 10-22-2011, 02:56 PM   #3
Thanks for reply, are you using faced or unfaced insulation?
Old 10-22-2011, 08:22 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
framing an actual wall in front of the foundation wall does take more time however it makes the rough in for electrical and plumbing much easier
plus the key thing is that the wall will be much straighter if framed properly... truewall foam conforms to all the irregularities of the foundation wall
the 1" airspace doesnt just go for the insulation but it also applies to the studs
woodworkbykirk is offline   Reply With Quote
Old 10-22-2011, 08:39 PM   #5
I used faced insulation but I didn't have to. I put a 4mil vapor barrier over the whole works.
Old 10-26-2011, 11:11 PM   #6
Registered User
Rewards Points: 526
No v.b. or faced insulation below grade, no air-space: http://www.buildingscience.com/docum...lation-systems
http://joneakes.com/jons-fixit-database/743
http://www.buildingscience.com/docum...gs?full_view=1
Gary
Old 10-27-2011, 08:49 AM   #7
Different areas of the country require different methods. The extreme cold in ND and Northern MN is something that has to be managed.
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
Basment Reno Questions jarn_76 Building & Construction 1 08-04-2010 05:12 PM
Finished basement humidity at 80% for unknown reasons denemante HVAC 6 05-07-2010 03:33 PM
GC Contract questions pharmboy General DIY Discussions 10 03-30-2009 08:35 PM
Hey gang, another Neewb here! 261,483 questions to follow! Portlandkids Flooring 6 08-30-2008 08:34 PM
