To Finish A Basement Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 09:06 AM   #1
to finish a basement height
What are the height restrictions on finishing a basement? I believe it is a minimal of 7'. My question really i s can I get a variance to finish a basement with a height that ranges from 6'10" to 6'11". Also is it possible to rent a concrete grinder and take the slab down 1" - 2" if a variance cannot be done?
wellcraft is offline   Reply With Quote
Old 11-20-2010, 03:08 PM   #2
Old 11-20-2010, 03:43 PM   #3
Civil Engineer
Rewards Points: 4,956
Basement height restrictions can best be addressed by your local code enforcement official. Yes you can rent a concrete grinder.
Old 11-20-2010, 04:02 PM   #4
Rewards Points: 1,092
Might it be cheaper/easier to bust the whole floor out, dig down a bit, and replace it? No idea what this is, but you could then run PEX in the new floor, too.
Old 11-20-2010, 06:21 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... You can rent grinders, millers, 'n saws, but the task is incomprehensible...
Definitely easy to start over..
The Following User Says Thank You to Bondo For This Useful Post:
jomama45 (11-21-2010)
Old 11-21-2010, 07:21 AM   #6
yeah i was very hopeful though. i know it sounded dumb to do that but it wont be worth chopping the floor out and digging. thanks anyway everyone.
Old 11-21-2010, 07:21 AM   #7
Rewards Points: 5,336
You would contact your local code office for the variance question.
The concrete grinder suggestion is ill advised at best and probably violates code.
Ron
Old 11-23-2010, 09:01 PM   #8
I've seen on-line basement remodeling guides for a number of counties. Check your local ".gov" site.
My county allows permits without drawings (and a very cheap permit!) for basements that comply with their "standards." Guidelines include ceiling height, egress rules, nailing intervals, electrical panel locations, clearance around furnace, and more. Height in my county is 7' and allows 6'6" around beams no closer than 3' apart.
Guy
DIY_ing_Guy is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
I am brand new here and I am about to finish my basement. LiquidSlap Building & Construction 27 03-04-2010 12:54 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Want to finish basement mopared Remodeling 3 02-20-2005 04:49 AM
