Old 11-06-2008, 10:00 AM   #1
Finger jointed pine vs. clear pine
Is primed FJP a good choice for fascia?
It is 15% cheaper than clear pine and it is already primed.
Will it hold up through New Jersey weather?
Dan B is offline   Reply With Quote
Old 11-06-2008, 11:49 AM   #2
Drywall contractor
As long as it's properly caulked, painted, and maintained it should be fine.The advantage to "clear" is ability to stain it.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-06-2008, 12:18 PM   #3
Thanks!
Old 11-07-2008, 12:03 AM   #4
The problem with finger jointed is that the joints will be noticable if exposed to moisture, since the wood swells at slightly different rates, causing expansion and the jointed outline. Be sure to use quality primer and paint. Otherwise, you can expect the joint to seperate in the future.
RemodelMan is offline   Reply With Quote
