Old 08-18-2011, 12:48 PM   #1
Thadius856's Avatar
Finding the Proper Tool - Adding Rosette Blocks to Existing Moulding
Looking around the house and getting ready to start throwing on moulding on some of the matching places. I want to use rosette blocks on the top corners of the door and window moulding. However, about half of the door and window moulding is already in place from the previous HO.
What tool would work best for removing the corner of the installed moulding to make room for the rosette blocks... without removing what's already installed?
I'm thinking one of coco's favorite Japanese saws would do the trick. But I'm only on page 100 of his thread, and want to be 100% caught up before I post. No spoilers!
Thadius856 is offline   Reply With Quote
Old 08-18-2011, 01:42 PM   #2
If you're careful, you can use that saw or a backsaw or a dovetail saw and a rafter square for the job.
Ron
B. Franklin 1759
Old 08-18-2011, 02:16 PM   #3
Something like this should work:
http://www.dremel.com/en-us/Tools/Pa....aspx?catid=94
Good excuse to buy one. Harbor Freight has cheaper, Fein much more expensive.
bob22 is offline   Reply With Quote
Old 08-18-2011, 03:09 PM   #4
+1 on using a multi-tool to for the job. You'd be amazed at what you can do with those things. I've done similiar work with mine, they will plunge cut and if you're careful they will cut preftectly straight.
mfc133 is offline   Reply With Quote
Old 08-18-2011, 10:13 PM   #5
Thadius856's Avatar
I worry about Harbor Freight's quality of product. I'll keep an eye on my Sunday paper, since I seem to recall always seeing lots of coupons there, including the usual 20% off one item.
Thanks!
Old 08-18-2011, 10:20 PM   #6
Yup a multi tool will do the work and many other projects around the house.
epson is offline   Reply With Quote
Old 08-18-2011, 10:51 PM   #7
An easier way would be to make thinner rosettes and tack them on top of the existing frame.
hayewe farm is offline   Reply With Quote
Old 08-19-2011, 07:46 AM   #8
That might work if the casing was flat. You couldn't use that on a beveled casing, like a colonial or clam(ranch).
Ron
B. Franklin 1759
Old 08-19-2011, 08:00 AM   #9
Super Moderator
Thanks!
I've got one--the higher quality of the two they sell.
It's a good solid machine ---and the blades are half the cost of everyone else s,----
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
adding window casing/moulding to existing windows Indy_Steve General Discussion 6 01-27-2008 03:58 PM
