Finding Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 11:54 AM   #1
DIY_Diva's Avatar
Finding joists
I live in a really old rental house, and I need to find the joists to attach a baby hammock to the ceiling. Unfortunately a stud finder doesn't locate them, and I have no idea how to find them. Any advice?
DIY_Diva is offline   Reply With Quote
Old 04-05-2011, 12:05 PM   #2
waterman1971's Avatar
Rewards Points: 154
Does the ceiling have any type of moldings? If so, maybe you can see where they nailed them
waterman1971 is offline   Reply With Quote
Old 04-05-2011, 12:17 PM   #3
DIY_Diva's Avatar
No, unfortunately it doesn't. Someone did a really hack-y remodel job on the whole house in the past couple decades.
Old 04-05-2011, 12:29 PM   #4
Rewards Points: 120
Baby. Old structure. Rental. Unknown construction. I'd go with an A-Frame that sets on the floor. Just 2 cents worth.
Old 04-05-2011, 12:31 PM   #5
fabrk8r
fabrk8r's Avatar
If there is a ceiling light fixture you could take it down and see from the opening where the joists are.
What I have done in the past when dealing with plaster and lath ceilings is drill a small hole in an inconspicuous spot and fish a coat hanger into the hole to determine the location and spacing of the joists. The pencil sized hole can be easily filled.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-05-2011, 02:30 PM   #6
Rewards Points: 5,336
If the ceilings are now sheetrocked, you can hold a flashlight parallel to the ceiling and pick out the filled nail holes if the remodel is as lousy as you say.
Ron
Old 04-05-2011, 02:53 PM   #7
the Musigician
DangerMouse's Avatar
IF the ceiling is sheetrocked, and maybe even if not, a good, strong ceramic type (read: hard drive) magnet should find any metal fasteners up there.
BUT.... I have to agree with DexterII as to the wisdom of continuing in this fashion.
DM
Old 04-06-2011, 11:17 AM   #8
Rewards Points: 3,130
What's above the ceiling? If it's the attic, go up there and look around.
Old 04-06-2011, 01:43 PM   #9
Either a rare earth magnet or a $39 metal detector will locate fasteners. However if it has drywall over an existing ceiling you may only find furring strips and I wouldn't want to hang from those.
hayewe farm is offline   Reply With Quote
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
