Filling Wide Driveway Control Joints - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 08:12 AM   #1
DIY Enthusiast
Filling wide driveway control joints
Over the years, the control joints in my 75ft driveway have spread approx. 3/4"-1". I'd like to fill them before winter and was wondering about the best procedure and products to do so.
Ed G is offline   Reply With Quote
Old 08-23-2011, 09:46 AM   #2
SteelToes's Avatar
Rewards Points: 150
Well you are going to need two different product/fillers to get this job done right.
First product to use is called Backer Rod.
Backer rod is a closed cell rope that is used to control thickness of the applied sealant.See attached pdf and note that for joints larger than the backer rod you can twist two strands of rod together.
Second product you're going to need is a polyurethane self-leveling sealant.This urethane base sealant stays permanently elastic and it expands and contracts with the concrete and temperature changes.Note that this product only works in horizontal applications.See attached pdf.
Filling wide driveway control joints-backer-rod.jpg   Filling wide driveway control joints-self-leveling.jpg
SteelToes is offline   Reply With Quote
The Following User Says Thank You to SteelToes For This Useful Post:
Ron6519 (08-23-2011)
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 08:07 PM
Driveway issues hbfl4 Landscaping & Lawn Care 7 03-21-2009 08:16 AM
Driveway & Garage Floor Control Joint detailedEye Building & Construction 4 01-28-2009 10:37 AM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 04:56 AM
Driveway gravel base is too wide. Help picsaro Landscaping & Lawn Care 8 09-08-2008 02:56 PM
