Filling In Trench - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 10:43 PM   #1
Filling in trench
How many 80# bags of concrete do I need to fill in 4 3/4 yards
secon is offline   Reply With Quote
Old 10-18-2010, 03:04 AM   #2
Rewards Points: 1,092
don't the bags have a volume on them? i believe CEMENT bags are one cubic foot, and the concrete may be the same. look on the bag, then calc it.
Old 10-18-2010, 03:09 AM   #3
jlhaslip's Avatar
Rewards Points: 394
A lot!!!
Might be worth calling a ready mix plant.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-18-2010, 03:30 AM   #4
Originally Posted by jlhaslip View Post
A lot!!!
True. At 27 cubic feet/cubic yard, and approx 1 cu foot/bag, you'll be getting in a workout mixing and dumping. That may be fun, or it may be tedious.
Old 10-18-2010, 06:50 PM   #5
Rewards Points: 4,454
60# bag = 2sf at 4" OR .666cf,,, that's over 40b for a cy,,, 4 3/4cy - 192+ bags - using some simple math, you can estimate the amt required here - http://www.quikrete.com/calculator/main.asp - no fudge for unven grade, spillage, or bowing forms - ONLY geometric volume,,, that works out to 1 hellacious job to me,,, mix almost 5cy of conc by hand ???????????????? not even in my youth
Old 10-18-2010, 07:32 PM   #6
Civil Engineer
Rewards Points: 4,520
I recently mixed less than 1 cubic yard of concrete in a wheelbarrow using sand, gravel, cement and water. VERY HARD WORK. And this was over three days, only did two or three posts per day. Believe me, I did not look forward to the mixing. Even with a concrete mixer, this was going to be one hell of a job, not likely to be repeated any time soon.
For your quantity, transit mix is the only way to go. Unless you can get the local high school football linebacker to mix.
Daniel Holzman is online now   Reply With Quote
Old 10-18-2010, 07:39 PM   #7
however, dan will agree it is honest work only 1 linebacker ?,,, think i'd want the whole defense + the offensive line but i'm older than he
Old 10-18-2010, 07:50 PM   #8
kwikfishron's Avatar
Rewards Points: 88
Personally I enjoy mixing sacks.
Shovel work is about the only time I can just work and turn the brain off. Itís almost like a break.
Iím only good for 1 pallet though. 5-6 is not going to happen.
Hire the whole team.
kwikfishron is online now   Reply With Quote
Old 10-18-2010, 10:53 PM   #9
Concrete & Masonry
Rewards Points: 470
200 bags at about $4.00 per bag = Ready mix is much cheaper & simpler.
jomama45 is offline   Reply With Quote
Old 10-19-2010, 07:58 AM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
Imagine the number of cold joints in that job.
Old 10-19-2010, 01:23 PM   #11
Rewards Points: 150
wow I just did 6 bags not too long ago. Joint compound buckets, and drill-mixer. This won't be easy. But get enough people, you can make a production line. One person to add the mix, one to add water, couple of mixers, can't be too hard. Well at least as long as you can get the mix delivered right to the site, and not have to carry all that. And I agree, this is when my brain goes to limp mode as well.
slickgt1 is offline   Reply With Quote
tools needed and best way to dig trench jolly Building & Construction 8 03-11-2010 03:16 AM
backfill & grass over a gravel trench ??? linboomer Landscaping & Lawn Care 4 05-09-2009 07:54 AM
opinions wanted on foundation trench sketch annie68164 Building & Construction 12 03-05-2009 12:38 PM
replace basement or dig trench w/tile? annie68164 Building & Construction 3 02-19-2009 07:17 AM
digging a trench for electrical...direction? Dusty Electrical 5 10-16-2006 03:44 PM
