Old 12-22-2008, 09:29 PM   #1
Filling in an old septic tank /cistern
While digging footers for our new deck today we discovered an old underground feature.
It is most likely an old septic or outhouse tank, or possibly a cistern.
Its about 4ft wide, and 5 ft deep, with stone and dirt walls. There are no pipes or things running into it, and no water is in it.The house was built in 1850 so who knows when it was put in, or covered over.
We are going to fill it in with gravel.
Two questions
1 - What size and type of gravel should I use
2 - I wanted to build a rainwater leech can I use this pit for this, and if so how should I build the piping.
troyce1 is offline   Reply With Quote
Old 12-23-2008, 12:10 AM   #2
Course pit run gravel should be fine!
Old 12-23-2008, 01:32 AM   #3
Moderator
Termite's Avatar
Be sure to perforate the bottom of it with a machine so water will leech out of it. A lot of people bury their downspouts and direct them to leech pits filled with gravel. Not a bad idea if it is far enough away from the house....10 or 15 feet at least.
Old 12-30-2008, 09:45 PM   #4
steel baron usa
Two questions
i would put a little cw pipe in there and cover with crushed 57's
have to be crushed you get a 98% compaction rate with this.
then you would have your own retention pond.
connect a lead a pipe out if you want and filter drain half way down on the back.
good luck
peace
Last edited by AtlanticWBConst.; 12-31-2008 at 06:51 AM. Reason: SITE RULES VIOLATION: Advertising Link Removed From Signature Line
steel baron usa is offline   Reply With Quote
Old 12-30-2008, 11:40 PM   #5
Knucklez's Avatar
i have the exact same problem! the cistern is not that big however, maybe 4'x4'. you can easily build a deck around this and then your cistern will be under your deck when you're done.
then you can run your down spouts into the cistern to collect water and a submersible pump to supply your graden irrigation system. all under the deck and hidden away.
that's my plan anyway
Knucklez
Knucklez is offline   Reply With Quote
Old 12-30-2008, 11:57 PM   #6
if your NOT filling with gravel etc,,,make DARN sure kids cant crawl under deck and fall in,,,they are TOO valuable to lose this way!! Most of those walls are real suspect and OLD, and may break in unless filled. I doubt anyone could survive long in cold ground water,,,let alone a kid. I could see gravel filled and drain out into a better suited tank for garden water.
4just1don is offline   Reply With Quote
Old 12-31-2008, 12:47 PM   #7
Knucklez's Avatar
yes, good point. in my case, the cistern is covered by concrete lid. i didn't even know it was there for years until i found it by accident while residing the house. the only access is a hole cut in the concrete about 3inches square this small entry is also sealed with a lid. so its safe from the concerns you listed.
Old 12-31-2008, 01:11 PM   #8
So long as it will be "permanently" under a structure such as a deck I would fill it in with either gravel or soil and not run water into it.
If it were to be used to catch water (and not have anything built over it) I would leave it hollow and properly covered.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
How long a run to septic tank? GregWCIL Plumbing 8 06-28-2008 04:04 PM
40s home still on Septic Tank? Inspection? twilightcall Plumbing 4 01-11-2008 07:35 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 12:33 PM
Magnolia tree + septic tank question/problem Jemo General Discussion 5 01-18-2007 10:08 AM
Foundation over abandoned septic tank handyman923 Building & Construction 2 09-29-2005 08:12 PM
