Filling In Old Heat Ducts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 07:33 AM   #1
Filling in old Heat Ducts
I have old heat ducts that have colapsed. They are underground and I am just trying to figure out what is the best thing to fill them in with. I have come up with foam insulation or sand not sure which one would be better Unless there is something else.
Thank You
sunshineg is offline   Reply With Quote
Old 03-02-2011, 10:46 AM   #2
Rewards Points: 5,336
Thank You
If they have collapsed, by definition, they can't be filled in. Even if they are partially collapsed, you would only need to fill the areas where the ducts entered the rooms.
Out of curiosity, where are these located and how did they collapse? On a slab house, they're covered by the concrete.
Ron
Old 03-02-2011, 10:50 AM   #3
any duct i have put in slab was encased in concrete prior to pour to eliminate this problem
The older I get the better I was
Old 03-02-2011, 07:27 PM   #4
The ducts are under a concrete floor in my Pool room. They are not completely colapsed just in some spots. Who ever put them in did not encase them in concrete. I am having a new FAG furnace installed and have to have new ducts run. So I wanted to fill in the old ones to try and prevent and more collapsing and any drafts that may come up into the room
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 07:32 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
