Filling The Gap At The Outside Corner Of A 45 Degree Framed Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 12:30 PM   #1
Filling the gap at the outside corner of a 45 degree framed wall
I've seen that the best way to fill the outside corner at a 45 degree wall is with a stud ripped and placed at the corner.
Problem is, I don't have a table saw. I have a chop saw, skill saw, etc.
Does anyone know of an angle-type product you can buy to bridge that gap and make it strong enough to sheetrock over?
Thanks.
Testarossa214 is offline   Reply With Quote
Old 01-07-2012, 12:36 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Testarossa214 View Post
...the best way to fill the outside corner at a 45 degree wall is with a stud ripped, (edit: built into the framing) and placed at the corner.
Then use your circular saw and something as a fence.
hint: rip the studs from both joining walls at 22
hth
Old 01-07-2012, 12:41 PM   #3
Rewards Points: 13,750
No such thing, A 2 X 4 can be ripped with a ciruler saw, you have to go slow and it works best with an edge guide that's attached to the saw, but can be done free hand. You use your index finger as a guide under the saws plate as a guide.
It does not need to be perfect.
Your going to need an outside sheetrock corner anyway that will cover the gap.
Most often I just leave the 2X's without any bevel, the sheetrock will just cover the gap.
Old 01-07-2012, 12:47 PM   #4
Ironlight's Avatar
I don't agree that you need to fill the corner unless you think it's going to be under unusual stress from traffic and needs that support. You're talking about like 1.5" of edge of each sheet. The 45-degree cornerbead should be adequate support and protection for most purposes.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
mae-ling (01-07-2012)
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
120 degree outside wall molding Bill625 Carpentry 7 10-21-2009 08:09 AM
filling gap in drywall corner listo Drywall & Plaster 6 01-27-2009 08:29 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
