Filling Crack Between Slab And Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 08:49 AM   #1
Rewards Points: 640
Filling crack between slab and block wall
well like most concrete, when the slab curred, it pulled from the wall a little.. The gap depending on the wall face ranged from 1/32" to 1/4" in width... each wall face the gap was the same size along its length.. what can I use to fill these? sometimes water seeps up through it when the sump pumps can't run fast enough (during very heavy rains) the land here is like a swimming pool, it just pools on the clay base... already have 2 sumps working with a 3rd backup pump, so not much more I can do about that, just want to get the cracks filled.. not sure what to use
BlueBSH is offline   Reply With Quote
Old 07-26-2011, 07:44 AM   #2
Rewards Points: 640
no one?
Old 07-26-2011, 10:50 AM   #3
AGWhitehouse's Avatar
You can use a caulk-like material made for concrete. Regular caulk won't work. The box stores may or may not have it.
Sounds like you want to do this to stop water. This caulking won't stop it.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-26-2011, 10:52 AM   #4
Originally Posted by BlueBSH View Post
no one?
Remember you're in an internet chat room. Expecting a 1 day turn around and then complaining when it isn't is the sign of ... well, I think you know where I'm going...
The Following User Says Thank You to AGWhitehouse For This Useful Post:
gregzoll (07-26-2011)
Old 07-26-2011, 09:40 PM   #5
Rewards Points: 1,478
You can fill the large parts of the gap with great stuff spray foam. Polyurethane caulk all the way around afterward. Home Depot has great stuff, but you have to order the poly caulk online, they have it on their site. You may need to scrape or cut some foam out of the crack before caulking over it. Get some mineral spirits also, poly caulk isn't fun to work with.
mikegp is offline   Reply With Quote
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 11:11 AM
Gap between slab and wall BlueBSH Building & Construction 4 04-25-2010 06:31 AM
Brick wall - concrete slab floor separation. DewmanTN General DIY Discussions 5 07-24-2009 09:57 PM
