Filling In A Concrete Archway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 08:06 PM   #1
Filling in a concrete archway
Hello DIYers! After lurking on the forum for months I am posing my first question and have high hopes. My beautiful 85-yr-old co-op building has beautiful concrete archways. I'd like to fill in one of them, creating a shallow alcove on the living room side with shelves. This could work nicely because the archway is considerably thicker than a regular wall- almost 9 inches.
One idea I had was to first mount the shelves to the concrete (need help with how to do that!) and then use them almost like studs to attach a piece of cut-to-fit drywall into the opening. All I would have to do then would be tape and mud the seams from the back. Is that a valid plan? Is it the best plan? If it is a workable plan, would one thickness of drywall be sufficient or would doubling up be safer?
I'm open to all ideas and advice!
KellyAL is offline   Reply With Quote
Old 08-02-2012, 08:48 PM   #2
Rewards Points: 13,300
Post a picture if you really want some replys.
Old 08-02-2012, 09:09 PM   #3
Thanks for the tip, joecaption. Here are pics.
Filling in a concrete archway-img-20120802-00187.jpg   Filling in a concrete archway-img-20120802-00186.jpg
Old 08-16-2012, 11:01 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
you could pre build a shelving system with plans to attatch drywall to the back of it and slide it in there. maybe build the shelf to the bottom of the arch and leave a portion of the arch exposed above the shelving system. Or, attach cleats to the concrete sides with tap con screws spaced to accommodate your desired shelving spacing and leave the back set in 1/2" for drywall to go there, nail/screw drywall to backside of shelves...
hand drive is offline   Reply With Quote
Tags
concrete wall , create alcove
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 05:03 PM
