Fill Hole In Foundation Wall After Gas Line Was Removed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 07:43 AM   #1
Question
Fill hole in foundation wall after Gas line was removed
My gas line runs through the foundation wall about 3 feet below grade and the gas meter is inside the house in the basement. I am having the gas meter relocated to the outside of the house. The gas line will no longer run through the wall. The utility will be moving the line and reconnecting it.
I wanted to know how to then fill in the hole in the foundation wall and make it waterproof? I don't know if the util company will be 'filling' the hole or not.
I was thinking of some hydro cement to fill the hole and roofing tar on the outside foundation wall or maybe some sort of epoxy coating.
ctbfalcon is offline   Reply With Quote
Old 05-03-2010, 07:51 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,624
Hydro Cement is the only way to do it. Do not use roofing tar for the waterproofer. They make waterproofer in caulking tubes that you can get at the local hardware store.
gregzoll is online now   Reply With Quote
Old 05-03-2010, 08:16 AM   #3
So fill the hole with the cement and on the ouside (and inside?) wall coat it/them with the waterproof caulk to make a thin membrane on the walls?
Tags
gas line wall fill hole
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 02:13 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 06:40 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
