Old 06-05-2012, 04:55 PM   #1
fill gaps in molding
How do I fill gaps in molding?
Abworks is offline   Reply With Quote
Old 06-05-2012, 05:09 PM   #2
Post a picture, where's the gaps?
If your talking about just the small gaps where it meets the wall then just use caulking.
I like Alex 230, expencive but does not crack like cheap painters caulking will.
Only make a small hole in the tip of the caulking tube, apply, wipe with your finger, then wipe with a damp sponge.
There only needs to be enough to fill the gap, there does not need to be any on the wall or the moulding.
oh'mike (06-05-2012)
Old 06-05-2012, 09:20 PM   #3
AHH, SPANS!!!
painters putty for nail holes and caulking for adjoining seams and cracks...
hand drive is offline   Reply With Quote
Old 06-05-2012, 10:14 PM   #4
I would never use any form of caulking for filling nail holes, painters puddy or Fast and final filler works far better, no shrinking and drys fast.
Old 06-05-2012, 10:30 PM   #5
sdsester's Avatar
Sort of a side comment but wire nuts are great for sealing the ends of partially used caulking tubes.
Do get yourself a quality caulking gun with a nice sturdy ratchet rod and trigger. I like mine that turn 360 degrees too. Keep a moist cloth handy.
sdsester is offline   Reply With Quote
Old 06-05-2012, 10:31 PM   #6
Old 06-06-2012, 05:18 AM   #7
Each situation is different. On one of my of my first DIY jobs I miter cut the molding that ran around the outside edge of a table just a little too short. I filled the gap with caulk but it did not have the sharp corner the molding would have had. Bugged me every time I looked at it!
Probably I would have done better using spackle. Overfill it, then sand it down to size.
puttster is offline   Reply With Quote
Crown Molding - Angles & Filling in gaps artlover13060 Carpentry 16 08-31-2010 11:20 PM
positioning molding joetab24 General Discussion 0 08-11-2010 07:38 AM
Newbie Redoing Kitchen Floor jcostas Flooring 2 05-21-2010 01:24 PM
How to fill gaps in hardwood floors ponch37300 Flooring 2 04-16-2009 05:30 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 12:01 PM
