Fill Dirt! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 07:01 PM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 776
I would do about 4" of crushed stone and then 2-3" of sand....then vapor barrier.....
Without the sand, the sharp rocks will most likely puncture the plastic and there goes your vapor barrier.
The Following User Says Thank You to ddawg16 For This Useful Post:
BigJim (01-25-2013)
Old 01-25-2013, 07:05 PM   #17
Rewards Points: 150
Ok thanks guys!
CJIII is offline   Reply With Quote
Old 01-25-2013, 07:15 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 776
CJIII.....us jeep guys have to help each other....so....how about some pics of your ride?
Old 01-25-2013, 07:32 PM   #19
Rewards Points: 150
I dont own a jeep!
Old 01-25-2013, 07:38 PM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 776
Oh............
I just assumed....CJ meant a CJ jeep....and the III is frequently used to represent a jeep grill......
Ok....you need to get a jeep....you can thank me later....
Old 01-25-2013, 07:47 PM   #21
Rewards Points: 150
My full name is Charles Jackson III so my nick name is CJ but I added the III.
Old 01-26-2013, 02:46 AM   #22
Rewards Points: 1,092
OK. I found the link. You are welcome to argue w/ Riversong, but no one on the GBA forum did at the time of his comment. You can also read over there, or buildingscience.com, about concrete wicking water. Bear in mind that not seeing water on the top of a post does not exclude the possibility that it also evaporated before being seen. This happens in basement floors that are "dry" until someone installs vinyl flooring and it pops, or they tape a sheet of visqeen to the floor and it gets damp underneath; not seeing is not a good indication of lack of (slow) wicking. And, no, bondo, it is not 4.5 miles. 5 kilometers is more like 3.1 miles. (K times 1.6 = M, or M times .6 =K, approx. Ex: a 10K footrace is 6.2 miles, each of which hurts.) Not that either number matters, unless you are building one H of a tall building. Pretty "wicked", isn't it?
http://www.greenbuildingadvisor.com/...oundation-wall
Old 01-26-2013, 02:56 AM   #23
Actually, I don't think the tiny holes from the gravel make a stink, unless the ground is very wet. Concrete is a super air barrier, and the gravel should be (SHOULD BE) a capillary break. I believe Joe Lstiburek mentioned "you can walk on your vb with golf shoes and it won't matter", or words to that effect. Still, my gut says to minimize the holes, like you said, and i don't think sand under the vb will hurt a thing. some of those spendy barriers would put a guy's mind to rest, but also empty his wallet. i bought some stegowrap for next to nothing, and it is incredible how much tougher it is than normal visqueen. it costs twice what 8 mil visqueen does, and it isn't even one of the real expensive barriers.
Packed Dirt Under Old Tub nixplix Building & Construction 6 10-20-2011 01:16 PM
Why fill the basement back in with dirt? nateshirk Building & Construction 18 04-19-2011 09:18 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 10:37 PM
cinder block and dirt foundations gatojojo Remodeling 1 06-20-2009 07:35 AM
Rats! Tunneling into my dirt crawlspace! PastorErik Pest Control 7 05-06-2009 10:27 AM
