Figuring Lumber For A Hip Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 08:08 PM   #1
Rewards Points: 150
figuring lumber for a hip roof?
I am looking at building a 12x20 detached garage with a hip roof, I know how figure how many common rafters I need, but I am stuck trying how many 2x6's I need to for the jack rafters.
CJIII is offline   Reply With Quote
Old 09-26-2012, 08:18 PM   #2
Rewards Points: 2,202
16" or 2' centers?
You need enough for the 12' ends to have full rafters plus any overhang times two.
so if your common rafter length is say 7' plus 2' overhang, add another 2' overhang to get 11' (12's work nicely), what you cut off your longest first jack becomes the shortest on the other side.
Clear as mud/
Basically you use your cut off to become the other side.
mae-ling is offline   Reply With Quote
Old 09-26-2012, 08:33 PM   #3
Rewards Points: 150
2' on centers.
Old 09-27-2012, 12:25 AM   #4
Order short than you'll know exactly what you need to finish.
tham
Tham is offline   Reply With Quote
Old 09-27-2012, 12:58 AM   #5
Rewards Points: 558
Take your drawing to your local lumber yard and they will do the material take off for you when you buy material.
epson is offline   Reply With Quote
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 02:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
