Fiberglass Insulation + Reflective Insulation Q? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 08:40 PM   #1
CAD
I have 2x4 exterior walls in my home and I'm wanting to get some more insulation besides what R-13 can give. Has anyone ever put the reflective barrier insulation up with it before? Below is the link to the instructions on how to install it and what it looks like. How well does this work as a vapor barrier? I have 4 mil plastic up right now. Also, it says unfaced but I have kraft faced up right now with a vapor barrier on top.. Is this a big problem? I know, two vapor barriers against each other, but does that faced stuff even work that well? Can I just take off the facing?
http://www.reflectixinc.com/images/u...2x4%200609.pdf
CAD is offline   Reply With Quote
Old 12-08-2009, 01:21 AM   #2
Registered User
Rewards Points: 5,212
The insulation has a vapor retarder, the other is a vapor barrier: http://www.panhandleinsulation.com/b...materials.html You would be compressing the insulation by 3/4" for the radiant barrier which would lose R-value. The gap in front would create a convective air loop that would do more harm than good: http://oikos.com/library/insulating_...lls/index.html This on attic radiant barriers: http://www.ornl.gov/sci/roofs+walls/radiant/rb_02.html Gives you an idea anyway.....
Be safe, Gary
Old 12-08-2009, 02:12 AM   #3
CAD
Thanks for the links. I thought it was odd that r 13 plus their r 3.4 or whatever equaling 14 was odd. What do you think about it in place of where a vapor barrier usually goes? Think it might be more effective?
Old 12-08-2009, 07:18 AM   #4
In order for a radiant barrier to work it has to have air in front of it -- it stops radiant heat, not conductive heat. If it's in contact with something then the heat will transfer through conduction. If you want it to do something in the summer and the winter, then it needs air on both sides.
If you want to get more insulation consider R-matte rigid insulation. It takes up a 1/2 inch, so you have to shim out the insides of your studs 1/2 inch.
pyper is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Where to go for the best price for fiberglass batting insulation? diy'er on LI Building & Construction 7 08-24-2009 05:01 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 10:40 AM
radiant reflective insulation vs fiberglass timchi29 Remodeling 1 10-07-2008 01:19 AM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
