Old 09-21-2009, 09:12 AM   #1
Fiberglass friend or foe
Today we had some builders working on our balcony which has leaked in the past. We decided to have a fiberglass base put in.
My question is that underneath the balcony I can still see the light through a gap that has not been filled with wood. It has however been covered with the fiberglass. Is this enough to stop any leaks? If it is not supported by the wood?!
I bought this up with the builders at the time and they said it should be fine. However we are having decorators in to cover underneath the balcony with a new ceiling. If water gets through the gap all the work will be ruined. I am very worried and would appreciate any advice.
Thanks,
Jenny
Jenuk is offline   Reply With Quote
Old 09-21-2009, 09:15 AM   #2
Xtreme DIY'r
How big is the gap that does not have wood?
Old 09-21-2009, 09:24 AM   #3
Its about a centimeter... Is that going to cause a problem do you think?
Old 09-21-2009, 11:25 AM   #4
Xtreme DIY'r
I doubt you will have a problem with an area that small
When roofing there are usually holes/ small gaps on older homes that are larger then that
Old 09-21-2009, 07:55 PM   #5
Hi Jenny
Hey Fiberglass is a great sealer if it dosn't get broken or cracked. Think of Boats ,Corvette's or your bathtub/shower. But if your deck moves whether by frost heaves, ( how high up are you?) or by Earthquakes, etc. it may leak. other wise it should be a great barrier for you.
telldon is offline   Reply With Quote
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 10:40 AM
fiberglass vs paper - revisited rtoni Building & Construction 3 03-25-2009 07:50 PM
Corrugated Fiberglass Roof theriver Roofing 1 09-16-2008 10:37 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General Discussion 10 01-31-2008 06:51 PM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 09:13 PM
