Fiberglass Column Strength - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-10-2007, 06:08 PM   #1
Rewards Points: 274
fiberglass column strength
The 8" x 8' fiberglass columns I bought are hollow and only about 1/8" thick. They are supposed to rated for 6,500 lbs. Does this sound right? They are made by afco industries. Thanks in advance for any advice.
ugabulldog is offline   Reply With Quote
Old 12-10-2007, 06:46 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
Is there any documentation or approvals by any independant authority or building code?
The capacity of a column depends on the length. A 6500# column at 8' long may carry only 1/4 that load at 12' or 16'.
concretemasonry is offline   Reply With Quote
Old 12-10-2007, 10:47 PM   #3
Rewards Points: 5,336
An 1/8" thick? Sounds Absurd.
Ron
Installing a structural fiberglass column Weekend Warrior DIY Building & Construction 9 11-19-2007 12:33 PM
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 01:24 PM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 08:13 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 08:16 PM
fiberglass column repair christoni General DIY Discussions 3 06-26-2005 11:15 PM
