-   -   fiber cement siding curling at gable edge. (http://www.diychatroom.com/f19/fiber-cement-siding-curling-gable-edge-181185/)
dabeast 06-03-2013 10:21 AM
1 Attachment(s)
Hello,
I'm having an issue with my fiber cement siding pulling away from my house at the gable edges and need some guidance on how to solve.
The drawing below is a rough illustration of what is happening.
The red lines are the places where it is happening.
It is pulling away from the wall at angle 1 in the green drawing.
When it was put up it wasn't nailed on the point of angle 1 as it kept breaking.
So how do I keep it from pulling away and flapping in the wind?
Thanks,
joecaption 06-03-2013 10:27 AM
A real picture would be better.
Did anyone paint the cuts on the ends as required?
If it was breaking then you were nailing to close to the outside edges.
Once we see a real picture you may be able to just nail a 1 X 4 over the ends to hold it down and just look like a trim board.
Windows on Wash 06-03-2013 10:37 AM
Rake board with a routed edge to terminate into.
Picture is helpful.
dabeast 06-03-2013 01:47 PM
2 Attachment(s)
Went home at lunch here are some photos.
All cut edges were primed before they went up but the snow started to fly before we got it painted. I wanted to solve the curling issue before I got it painted this summer.
All the siding is 1/8'' from the edge of the trim as per install instructions.
From what you are saying I'll need to add another board over the tips?
Thanks,
joecaption 06-03-2013 02:18 PM
What in the world did someone try to use as drip cap? Looks like someone tryed to use vinyl flashing.
I know my siding nailer would get that back down without breaking it.
Most likly your trying to hand nail so you might try and predrill with a masony drill then use trim head stainless steel siding nails.
Is there any plywood or OSB under that area?
dabeast 06-03-2013 02:35 PM
We used a siding nailer for the whole job when when we tried to pin down the points they would just crack.
Where would you suggest we nail to prevent that issue from happening?
As for the metal at the top it was a bad attempt at fixing uneven roof line with the plan to then put a regular drip cap on when the new roof goes on later this summer. It will be removed and something else done.
djlandkpl 06-03-2013 04:24 PM
Originally Posted by windows on wash (Post 1194185)
rake board with a routed edge to terminate into.
... +1
Nailbags 06-03-2013 04:39 PM
well your going to have to face nail it come in about 2 inches i would use 1-1/2 roofing nails and just face nail it apply paint and it should turn out ok.
joecaption 06-03-2013 04:45 PM
Roofing nails are going to leave big exposed heads that may rust.
kwikfishron 06-03-2013 04:54 PM
199 Attachment(s)
Use a 7d ring shank siding nail and predrill the hole.
https://encrypted-tbn3.gstatic.com/i...WTNy96yLBV2xUE
dabeast 06-03-2013 04:58 PM
I could predrill the holes it is only about 50 on the house.
Come in 2 inches from the end on the bottom of the board as it sits?
Should I try with the air nailer first at the same spots and see how it goes?
kwikfishron 06-03-2013 05:06 PM
199 Attachment(s)
I wouldn't. :no:
Nailbags 06-04-2013 12:47 AM
you don't need to pre drill for nailing In fact Hardi plank says no to it. Just sink em in with a hammer and yes you can use a nail gun.
Windows on Wash 06-04-2013 06:22 AM
What an interesting look.
What is up with that rake board trim too?
hand drive 06-04-2013 07:09 AM
angle the nails in an upward fashion to get to more meat in the wall, you will probably catch the gable wall plate under the rafter if there is one. your rake fascia trim piece is likely the size of the rafter so if you angle long nails it could catch the rafter. if you were having splitting problems it could have been associated with the cold weather which is over so no need to be concerned as much but it will still split
