Fiber Cement Shake Siding Around Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 01:36 PM   #1
Fiber Cement Shake Siding around windows
I'm installing Maxitile Fiber Cement Shake (Straight Edge) Siding on a newly enclosed porch. (See the Maxitile website, MultiShakes for details) These are 16" x 48" panels with a 7" maximum exposure (so a 9" overlap). I'm blind nailing the overlap, then putting the next course on 7" above, and repeating the process.
When I come to a window or the top of the wall, I assume that I have to cut off individual shakes to appropriate height to meet the trim at the top and cover the overlap on the previous course, but I'm not sure.
My questions:
1. Is there another way to do this besides cutting individual shakes and face-nailing? (The trim, 7/8 cedar, is already up)
2. If I do have to face nail them, is there a way to hide the nail heads, or do I just live with them? Should I countersink those nail heads slightly and then cover them with fibercement patch?
Thanks in advance for your thoughts.
smithta3 is offline   Reply With Quote
Old 08-06-2012, 07:47 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
Hi, Just a galvanized type nail, ( 4d common galvanized ) most likely for your application where face nailing is needed. You do not want to break the face of the siding with the nail ( countersink) , just nail until the back side of the head of the nail makes it to the siding and another slight tap to snug it up. once the siding is stained the nail heads should blend in ok.
hand drive is offline   Reply With Quote
Old 08-06-2012, 10:47 AM   #3
Thanks!
Much appreciated.
Tags
fibercement shakes
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
Vinyl siding over old wood shake?? ttam Building & Construction 15 10-26-2010 08:50 AM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
