Fiber Cement Install Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 04:39 PM   #1
Rewards Points: 358
Brought purchased my house was remodeled and T1-11 was used as the new siding. They installed T1-11 over the existing plywood sheathing so I have double thickness plywood. Due to the windows being installed then over the T1-11 it is not easy to just tear it off, so my plan is to just re-side over the T1-11. The problem is on the gable end they did not install T1-11, so I just have the original plywood us there causing a difference of about a half inch.. So I have two options to flush out the siding, I can slap up another layer of sheathing to make the gable end the same thickness, or I can just add 1/2" furring strips. Furring strips would be much easier and somewhat cheaper in my opinion, but I am not sure what type of end product I will be getting with this. I guess it just seems very strange to have nothing solid behind the siding.
Any advice?
cbzdel is offline   Reply With Quote
Old 07-25-2012, 06:02 PM   #2
kwikfishron's Avatar
Rewards Points: 86
There’s no problem going over what you have assuming it’s all in sound shape.
I’d sheet the gable, much easier to maintain a drainage plain with the house wrap and I prefer Hardie to be installed over a solid surface.
It is ok to install Hardie over furring strips, I just prefer not to.
kwikfishron is offline   Reply With Quote
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 06:03 AM
Question: Fiber Cement Shingle Siding Installation Greg D Building & Construction 2 09-06-2011 09:41 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
Humidifier Install Question - Inside A Coil OK? dwolek HVAC 1 12-21-2009 01:37 PM
Painting fiber cement siding david.plymouth Painting 5 09-06-2009 06:25 PM
