-   -   Fiber Cement Install Question (http://www.diychatroom.com/f19/fiber-cement-install-question-151517/)
cbzdel 07-25-2012 03:39 PM
Brought purchased my house was remodeled and T1-11 was used as the new siding. They installed T1-11 over the existing plywood sheathing so I have double thickness plywood. Due to the windows being installed then over the T1-11 it is not easy to just tear it off, so my plan is to just re-side over the T1-11. The problem is on the gable end they did not install T1-11, so I just have the original plywood us there causing a difference of about a half inch.. So I have two options to flush out the siding, I can slap up another layer of sheathing to make the gable end the same thickness, or I can just add 1/2" furring strips. Furring strips would be much easier and somewhat cheaper in my opinion, but I am not sure what type of end product I will be getting with this. I guess it just seems very strange to have nothing solid behind the siding.
Any advice?
kwikfishron 07-25-2012 05:02 PM
199 Attachment(s)
There’s no problem going over what you have assuming it’s all in sound shape.
I’d sheet the gable, much easier to maintain a drainage plain with the house wrap and I prefer Hardie to be installed over a solid surface.
It is ok to install Hardie over furring strips, I just prefer not to.
