I've read up on what threads I could find on drywall finishing (rather than patching) and think I have the general procedure down but wanted to clarify a few questions I had.
The wall in question is about 10 feet of new drywall as part of a kitchen bar wall, about 48" high, one exterior corner that has a metal corner bead installed already. I have a small bucket of pre-mixed compound (blue lid) and 2 knives (4" Joint Knife [?] and a 12" Flexible Drywall Knife) & a mixing tray. Once it is all finished it will be painted with the potential for a hard finish (Laminate?) to be applied at a later time.
If I understand it all correctly (
questions in blue) -
- Apply mud to the butt joint & along the corner bead. Is the blue lid mud ok for this - I'd rather not buy a lot of products that I might not need if I can avoid it. What consistency should the mud be? Straight from the bucket or thinned?
- I tape (paper tape) along the corner bead and the butt joint. Do I need to tape the corner bead? I've seen it done both ways. Why or Why not?
- With more mud smooth out the tape and lay down mud over it. Same blue lid mud ok there?
- Smooth and feather. I'm actually half-way decent here. Mild nerd OCD + lots of art classes finally pays off.
- Let it dry. How long? I've read between 2 hours and 24 hours.
- Light sand. Is there a prefered grit paper? I've seen anywhere from 80 to 120 recommended.
- Thin mud and feather out along the joints. What consistency am I going for here?
- Light sand. Is there a prefered grit paper? I've seen anywhere from 80 to 240 recommended.
- I've seen 'sponge' recommended. Is this a wet sponge or a sanding sponge?
There are also two areas where the wall butts into an existing wall - should these be mudded together or filled with painters caulk and painted over? Both walls will be the same color and the existing wall is already painted.
Thanks!
