FENCE: What Concrete For Post Extension? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 10:42 PM   #1
Rewards Points: 119
Heya guys!
I am planning to raise (extend) my 6' chain link fence posts for about couple of feet.
What I am about to do is:
- make some kinda clog (paper,rag,etc) and push it inside existing post about 1ft below from the top;
- insert a 2 ft pipe of less diameter, so it will move freely:
- add necessary extension of same diameter on top of existing post;
- cover the seam between existing post and extension with electric tape;
- pour some kind of concrete;
- wait before it bonds...
1.Will this work?
2.What kind of concrete/glue would you recommend for this?
Thank you in advance,
almazon
almazon is offline   Reply With Quote
Old 10-06-2013, 06:43 AM   #2
cortell's Avatar
Rewards Points: 504
That sounds like quite the hack. Have you thought through how much time that will save you over just replacing the posts? Even if the end result is structurally stable (doubt it), its going to look ugly as hell. Even if it takes you twice as long, the end result will be well worth it.
cortell is offline   Reply With Quote
The Following User Says Thank You to cortell For This Useful Post:
joecaption (10-06-2013)
Old 10-06-2013, 07:01 AM   #3
Rewards Points: 2,064
What you need is socket weld fittings, a welder and a weldor.
http://www.valvias.com/connection-va...ocket-weld.php
Old 10-06-2013, 07:04 AM   #4
kwikfishron's Avatar
Rewards Points: 1,002
I can think of a few different ways to accomplish what you want to do (extend the fence) but none of them involve rags or electrical tape.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 10-06-2013, 07:25 AM   #5
An old Tradesmen
Rewards Points: 8,176
Duct tape? LOL
Old 10-06-2013, 09:01 AM   #6
Rewards Points: 119
Gotcha!
Somehow I did not expect any better inputs.
I will keep you posted... with pictures.
Salut!
Old 10-06-2013, 09:08 AM   #7
An old Tradesmen
Here is a link to a supplier of metal fence extensions. Might be much easier, and nicer looking then what you will get the way your thinking of doing it. They list extensions up to 2 foot.
The Following User Says Thank You to beenthere For This Useful Post:
kwikfishron (10-06-2013)
Old 10-06-2013, 09:39 AM   #8
Rewards Points: 119
I was looking into this, but after visiting my local fence store and talking to the guy who runs it I kinda liked the idea with "poured concrete"
Old 10-06-2013, 09:58 AM   #9
An old Tradesmen
If your fence post are 2", and you insert a 1.5" pipe inside of it. You'll have a 1/4" of play to contend with where the concrete won't be after you pour. So it will be a loose extension.
Plus, the concrete in the pipe where the 1.5" pipe ends are won't be as strong as you think. Allowing it to crack/break easy and give you a loose extension.
Old 10-06-2013, 11:35 AM   #10
Rewards Points: 119
Ok, here's how its suppose to be:
Its NOT really a concrete. Its like some kinda glue or epoxy or liquid plastic. Remember that's why I came here... to ask What Concrete For Post Extension to use...
Its not supposed to be uglier then those extenders in that link and it is gonna be strong.
BUT, after giving it a second thought I decided to go with those extenders beenthere sent. Why hassle with that concrete if I will have ready product?
Thanks beenthere!
I will let you know how it goes!
Old 10-06-2013, 12:23 PM   #11
An old Tradesmen
Thank you.
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Fence posts in new concrete patio Dornier Building & Construction 12 01-14-2012 12:30 PM
Fence Post Replacement in Existing Concrete ggunder Landscaping & Lawn Care 4 11-26-2011 09:21 PM
Concrete Patio Extension redhermes Building & Construction 14 11-18-2008 10:09 PM
