Fence To Vinyl Siding?? Please Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 12:50 PM   #1
Fence to Vinyl Siding?? Please help!
Hey everyone,
I am getting a fence installed soon. The problem is that the only place to attach the fence to our house is either the concrete (which we have a basement) and our vinyl siding.
I heard its bad to drill through either of those. Any help or tips? There is no where else we could attach this fence because then there will be a 3 foot gap going into our neighbors since we are attached townhouse.
Thanks in advance!
Anthony
mrmrscamp is offline   Reply With Quote
Old 04-26-2012, 01:12 PM   #2
Rewards Points: 12,858
Pictures please!
Your right it's almost never a good idea to attach anything to the side of the house.
When I have to do it I remove the siding and add a vinyl siding block with a piece of 3/4 plywood or advantec inside of it, then reinstall the siding around the siding block. That way there's no leaks and the siding can still move.
Old 04-26-2012, 01:16 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by mrmrscamp View Post
Hey everyone,
or... to the STRUCTURE of the house BEHIND the siding.
I once had a fence that attached to a piece of angle iron...
and the angle iron was bolted to the brick wall. It worked well.
This sort of transition is the direction you should explore.
Off the top of my head... I'm seeing some heavyish lag bolts run through trim sleeves (eg a 1" nipple of PVC pipe) which in turn attach to fence hardware or an angle like I used to have.
hth
Old 04-26-2012, 02:17 PM   #4
Once I get home I'll snap a picture. It's a brand new townhouse so I am hesitant to take off the siding (or drill through it for that matter). I'll post a picture soon. Thanks again
Originally Posted by joecaption View Post
Pictures please!
Old 04-26-2012, 06:46 PM   #5
Okay attached is the picture but don't mind the white vent (it won't be in the way). Let me know your thoughts. I keep hearing how bad it is to drill into the brand-new vinyl siding, but yet other people say don't drill into that concrete slab at the bottom of the stairs because it might jeopardize the foundation. Your thoughts?
Thanks in advance,
Anthony
Pictures please!
Old 04-26-2012, 06:59 PM   #6
Where is this fence going to go?
Looks like a hedge to the side of the two stairs, where can you go once your down the stairs?
Old 04-26-2012, 07:02 PM   #7
It would go to the left of the concrete and stairs. It's just grass, no hedge (bad picture angle I guess)
Old 04-26-2012, 07:09 PM   #8
Removing enough siding to to do this is about a 5 min. job and will do no damage to the siding, It's done all the time using a tool called a zipper.
If you use Tap Cons and angle brackets it could be just attached to the walk way.
Old 04-26-2012, 07:59 PM   #9
Which potential risks might happen though if I go through that cement slab instead of the siding? Its a new townhouse so I just don't want to mess it up long term. Is going through the concrete safer you think or is siding safer?
Old 04-26-2012, 08:20 PM   #10
It's going to do no harm either way if it's done right.
Old 04-26-2012, 08:22 PM   #11
Since the concrete is there which method would you do ?
Old 04-27-2012, 12:50 PM   #12
I think I figured out a safe solution but please give your input.. Would installing an aluminum FLANGE to the concrete be the safest to not jeopardize the foundation and the siding?
Thanks in advance..
Old 04-27-2012, 12:56 PM   #13
Rewards Points: 528
Thanks in advance..
If I understand correctly that would work.
Please, Joe has given you the answer several times, either will work and neither is bad.
Now if you are attaching a fence, do you not have a post to attach? If you do, you should attach it to the vinyl portion and to the cement portion.
framer52 is offline   Reply With Quote
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
