Originally Posted by Ckb3216
Im planning to put up 6 ft wood fence (common stockade fencing) they are 6x8 panels, i am going to buy the 4x4 8ft posts. Now i was going to space the posts 8ft apart so the panels could meet at the posts but i also heard of spacing them 6ft apart to make the fence more sturdy, some reason this does not make sense to me. Anyone who has experience with this clear this up? What is the best way to space them?
6' Spacing with 8' panels? Your right, doesn't make sense.....you still need a post where the two panels meet......
If you do the posts right....8' will be fine.....
Make sure you use PT posts.....and if it's more than 4 or 5 posts....rent an auger.....unless your into S&M and just want the exercise.....
The way I have done posts....I set the 2 ends.....plumb and straight....then I run a string from top to top and and another one at the base....then align the other posts to those strings.
