Old 06-25-2012, 06:12 AM   #1
fence post
what size hole for 6x6 post
palletpat is offline   Reply With Quote
Old 06-25-2012, 06:31 AM   #2
Master General ReEngineer
Bondo's Avatar
fence post
Ayuh,... It'll take an 8" hole for it to Drop in...
Old 06-26-2012, 09:01 PM   #3
Knucklez's Avatar
fence post
8" hole is correct if you backfill with soil. but some fence posts should be set in concrete. for fence post you need to put the end post (end of the line) or corner post into concrete and every 3rd post into concrete. concrete is cheap, so don't worry. for 6x6 post you need hole diameter of 11", but dig 12" to give wiggle room for fence alignment. also for posts that sit on either side of a gate should be in concrete.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Quick Release Fence Post JasonCA Building & Construction 8 02-14-2012 10:15 AM
Fence Post Tar and Rocks/Pebbles? JasonCA Building & Construction 4 02-14-2012 01:12 AM
Fence Post Question handy man88 Building & Construction 4 06-14-2011 04:55 PM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
Privacy Fence Post 10' Apart wrldruler Building & Construction 6 09-02-2008 11:59 AM
