Fence Panel / Post Width: 10' VS 8' - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 09:15 PM   #1
Fence panel / post width: 10' VS 8'
I'm replacing a 50' straight line run of a stockade fence.
Plan on buying individual pieces as opposed to the pre-made panels; I'd rather use PT 2x4's for the stringers as opposed to the 2x3's on the pre-made panel sections.
I'll be starting in the middle an existing fence where a previous section had been replaced and terminating at a heavy / stable 4" square metal post that is our strike post for an automatic gate for the drive.
In order to avoid the previous post and therefore not to have to dig out the old posts I plan on using 8' 2x4's and then when I get to the end I can either go with a 10' span or keep the 8' span and then a short 2' span just before the end at the metal gate post.
Is a 10' span using 2x4's acceptable? Pushing it?
My wife thinks a single 10' span would look better but I think an 8' & short 2' span will look fine.
Even though the gate post is very secure / stable I'm thinking that having a fence post two feet away would be more supportive over time.
(Post are on our side of property and not an area we see when enjoying the yard but is seen when driving thru the gate).
Thoughts?
Am I over thinking this?
CZSteve is offline   Reply With Quote
Old 05-26-2011, 09:27 PM   #2
kwikfishron's Avatar
Rewards Points: 1,002
I think it's pushing it. Go 2x6 for that section and you both win.
kwikfishron is online now   Reply With Quote
Old 05-26-2011, 09:28 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can you say: Sag?
XXX
Old 05-27-2011, 02:36 AM   #4
Or would it make more sense to make all the sections 7.14' and just split it evenly and each span would be slightly stronger anyway?
When I'm dead and gone will the next owner be dog cussing me for doing that???
Old 05-27-2011, 06:37 AM   #5
Thatís how Iíd do it, 8í is over span IMO.
Wood Fence with metal post BDestroyer8418 Building & Construction 8 09-24-2011 09:49 PM
concrete anchor for cedar fence post matt76 Landscaping & Lawn Care 0 06-25-2010 08:04 AM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 01:19 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Non-Dirt/Concrete Base for Chain Link Fence Post suncowiam Building & Construction 7 06-04-2009 12:56 PM
