Old 06-20-2011, 06:34 PM   #1
Felt Paper and Fiber Cement Siding
I am planning to replace the siding on the front of my house with fiber cement siding (Certainteed Random Square Shingles). Both Certainteed and James Hardie recommend using a Tyvek type house wrap. My preference would be to use 30# felt paper instead of the housewrap. Are there any potential problems or issues with using felt paper instead of house wrap?
Thanks in advance.
Greg~
Greg D is offline   Reply With Quote
Old 06-20-2011, 06:37 PM   #2
Mod
kwikfishron's Avatar
#30 felt is what I use.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Greg D (06-20-2011)
Old 06-21-2011, 03:03 PM   #3
Next Time...New Build
We always used housewrap but put pieces of felt paper behind any seams just in case of any shrinkage you wouldn't see any of the housewrap peeking through.
RickyBobby is offline   Reply With Quote
Old 06-21-2011, 03:24 PM   #4
Felt is cheaper, and if water does get behind the siding then there will be mold that follows because the paper does not breath as well as the house wrap. You are putting a cement siding on, which is a premium product, and it will last for many years. Do you really want to put a cheaper underlayment on and take the chance of having to tear off all your siding in the future because the felt wouldn't breath right. Spend the extra money on the house wrap. It is more efficient at breathing and holding water away from your framing. Always overlap your housewrap 4 -6 inches and use the tape for housewrap and tape EVERY seam. I hope this was helpful and if it wasn't, let me know...
http://www.handymanhill.com
Stephen Hill is offline   Reply With Quote
Old 06-21-2011, 03:28 PM   #5
There shouldn't be any shrinkage in fiber cement boards, minimal if any...
Old 06-21-2011, 04:41 PM   #6
Thanks for your reply Stephen. My consideration of using felt paper is not because it is less expensive but because I believe it would do a better job of keeping water out. If I were to use the housewrap I would tape all of the seams but what about all the holes created by attaching the wrap and nailing the siding? I would think that water could seep right through those holes to the sheathing, whereas with the felt they would be sealed up. That being said, one of the good things about the shingle panels is that there won't be any exposed butt joints like with lap siding so potential water penetration points on the area that I am re-siding is pretty much limited to where the panels will butt up to the corner trim and window trim.
Thanks again.
Greg~
Old 06-21-2011, 05:06 PM   #7
Thanks again.
Greg~
The same thing will happen with the felt paper. That's not why you would pick one product over the other.
Felt paper has been used under stucco, brick veneer and stone forever without an issue.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (06-22-2011)
Old 06-21-2011, 05:52 PM   #8
75 percent of jobs I have uncovered with a paper have had surface mold. I have uncovered it under stucco, under brick, and under hardwood floors and in most cases there was surface mold do to moisture. Water is always going to get back there, if not water then it will be moisture, the house wrap breathes and will drive the moisture out the felt paper will not. As for nail holes, I always blind nail siding so that there is no nails showing if you do face nail you can caulk the nails. In my experience home owners use felt paper and professionals use house wrap. Ask Mike Holmes. I hope this was helpful.
HTTP://WWW.HandymanHill.com
Old 06-21-2011, 06:59 PM   #9
Tom Struble's Avatar
with new energy codes coming up,it's eventually going to be necessary to tape all seams in the wrb,felt to my knowledge can't be [unless somebody now has a compatible seam tape
Hardie now has their own wrap that is engineered to the climate zone you live in
i don't argue wrb type,just make sure it's a non perforated one and is installed correctly
Tom Struble is offline   Reply With Quote
Old 06-21-2011, 07:03 PM   #10
Quoting Mike Holmes? Really?
Have you seen some of the crap he's done?
Ron
B. Franklin 1759
Old 06-21-2011, 07:25 PM   #11
I agree whole heartedly. I have just found the house wrap to be a better product in my opinion that's all I was trying to say.
Old 06-21-2011, 07:28 PM   #12
Mod
75 percent of jobs I have uncovered with a paper have had surface mold. ]
75% of how many jobs?
Mike's your hero...huh.
-NEW MEMBERS-
Old 06-21-2011, 07:32 PM   #13
I actually have not seen some of the crap he has done. If you would please send me a link to some of it. Not that I don't believe you but I have to see things for myself. I just graduated college a few years back and started a company with my brother and have seen a lot and done a lot, but I also realized I don't know everything. I just tell people what I have found in my experience. I hope we are not on bad terms...
Old 06-21-2011, 08:46 PM   #14
i think your wrong
Old 06-21-2011, 08:48 PM   #15
i think your wrong
That's cool. So, felt paper and house wrap are equall or is felt the better application?
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 10:09 PM
Proper way to flash exisiting windows when installing new fiber cement siding, plus.. deminimis Carpentry 8 09-23-2010 10:55 PM
Installing fiber cement siding over existing siding elsobrider Carpentry 20 08-04-2010 06:34 PM
