Old 02-17-2010, 12:05 PM   #1
Post
faux stack stone - mortar
I'm putting faux stack stone on an indoor fireplace.... framed with cement board bonding surface... not using expanded metal. I have types "S" and "I" cement and masonary sand available (unmixed). I intend to lay stone from floor to hearth then hearth to mantle then mantle to ceiling in three installations. so far, so good????
Q: In what proportions do I mix cement and sand and to what consistancy??
Should I use type "S" or type "I" cement?
David W is offline   Reply With Quote
Old 02-20-2010, 08:15 PM   #2
Contractor
Brickie's Avatar
What is the brand of faux stone?
Northwest Indiana Masonry
Brickie is offline   Reply With Quote
Old 02-23-2010, 10:44 AM   #3
Concrete & Masonry
Maybe I'm having a brain fart, but what's type "I" cement, never heard of it, or at least I don't think so.
Tscar? ConcMsnry?
jomama45 is offline   Reply With Quote
Old 02-23-2010, 01:19 PM   #4
Master Joatmon
Chucky Jesus's Avatar
I'm just finishing up using Pro-Stone from Owens-Corning on a basement project. I've been using a pre-mixed masonry mortar that is from Quikrete called CSC-4 (Code # 1191-84). They also have a product called Veneer Stone Mortar (Code # No. 1137). I can only get the CSC-4 locally. Both are specifically formulated for use with Veneer Stone (natural or manufactured). It takes me about three hours to use up an 80lb bag of CSC-4 and it stays workable the whole time as long as I keep it mixed. (about every 1/2 hour). I tried finding what proportions of sand, cement, lime they use, but it looks like it's a secret. That being said, I did a google search on this subject and found a thread:
http://www.diynetwork.com/how-to/how...dex.html#step5
Their formula was a 2 to 1 ratio of sand to cement. The sand was "mason" sand and the cement was Type-S. Looks like you're good to go.
Chucky Jesus is offline   Reply With Quote
Old 02-23-2010, 01:32 PM   #5
Concrete & Masonry
Tscar? ConcMsnry?
Disregard, wiped the cobwebs off the brain. I assume he meant Type I Portland. Don't use the Portland alone.
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 09:06 AM
Help: Installing Faux stone over interior concrete surface cips General Discussion 21 12-28-2009 12:42 AM
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 10:43 AM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 08:44 PM
