Fastner Type And Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 08:24 PM   #1
Fastner type and size
I am resheathing my 2 story 2x4 construction 1974 residential home prior to applying vinyl siding. The sheathing is currently a 5/8 to 3/4" gypsum black paper exterior grade product. I am not removing this, but going over top with a 1/2" EXTERIOR GRADE 4 PLY PLYWOOD and a TYVEK BARRIER. There is no concern regarding wall depth as I am installing new construction windows as well. All product is on site and ready. I initially purchased bostitch 2 3/8" ring shank galvanized S8DRGAL-FH, but don't think they are long enough. Do I need th 10d's 3"? Since the total sheathing depth will now be 1 1/8" to 1 1/4"
Housecrzy is offline   Reply With Quote
Old 10-20-2012, 09:31 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
i would definitely go to the longer nails. reason being the gypsom product has zero holding power for the fastener it just acts as a spacer which reduces how deep into the stud the nail penetrates. also it creates a potential for shear sag which is when the weight of the sheathing can cause the nails to bend and the sheathing will sag. . similarly youll want to be using longer nails when you go to hang the windows by nailing through the nailing flange and with the vinyl siding. 2 1/2" siding nails will work for that.
woodworkbykirk is offline   Reply With Quote
What size and type wire should I use? Iman Electrical 4 06-20-2010 02:57 AM
Size of Wire & type of wire agman Electrical 6 11-10-2009 09:13 PM
What size and type of nails to use keviadams General DIY Discussions 2 09-28-2009 01:25 PM
Nail size and Type ????? mjkpainting Carpentry 7 11-21-2008 03:06 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
