Fastest And Cheapest Front Porch And Handrail To Pass Inspection? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 10:28 AM   #1
the Musigician
DangerMouse's Avatar
Fastest and cheapest front porch and handrail to pass inspection?
I need to get these last couple things done this spring and get the inspector out of my life. The front porch/deck/landing/whatever is the last thing I have to do. Any suggestions? Any pre-made kits out there? There's a concrete pad there now, so I want to avoid having to set posts. Suggestions?
Thanks guys!
DM
Old 04-04-2011, 10:35 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
I do not know the price, but for fast and easy you can look into a precast unit-step type of solution. They can cast and form any size you need, then pick it up and install it.
hyunelan2 is offline   Reply With Quote
Old 04-04-2011, 10:54 AM   #3
the Musigician
That was one of my thoughts. But I'm thinking the $$$ is going to be beyond my budget. Po(
Any guesstimate how much something like that would be? I'd call a couple places in the yellows but I'm uploading a large file on dialup and it'll be an hour or more still.... dialup stinks.
DM
Old 04-04-2011, 11:01 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Try a modular home company.
They have temp stairs all the time.
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 11:05 AM   #5
kwikfishron's Avatar
Rewards Points: 186
Thanks guys!
DM
Iím shocked, with all the stuff make and show here, trees to trim even and youíre looking for a pre-made porch kit?
kwikfishron is offline   Reply With Quote
Old 04-04-2011, 11:16 AM   #6
the Musigician
I know, I know.... I designed and built the BACK porch: Outside Baluster Spacing
BUT.... I just want something fast and cheap to get the inspector out of my life.
DM
Old 04-04-2011, 11:22 AM   #7
Rewards Points: 186
Well the second one should go twice as fast.
You can get wood at a lumber yard, you donít have to start with a tree.
Old 04-04-2011, 11:36 AM   #8
the Musigician
but.... but.... my lumber yard IS my yard!
But I need fast and cheap...
DM
Old 04-04-2011, 11:40 AM   #9
make your house a lock box that he needs to figure to enter, maybe he'll just go away
The older I get the better I was
Old 04-04-2011, 11:42 AM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Move the back stairs to the front of the house.
Get a Beware of the Dog sign and don't let the inspector in the back yard.
Just trying to help.......
The Following User Says Thank You to tcleve4911 For This Useful Post:
BigJim (04-04-2011)
