Fastening Structural Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 08:48 PM   #1
Question
Fastening structural beams
I am adding a structural 4X4 post to a load bearing wall. I am looking for a method of fastening the post to the concrete without using a galvanized post base. The post will be exposed and stained and I would like to make it look as clean as possible at the floor. Angle drill and countersink tapcons maybe? Just do not really want the fastener to show.
Help...
PaddyHutch
PaddyHutch is offline   Reply With Quote
Old 01-10-2009, 09:38 PM   #2
Help...
PaddyHutch
What's wrong with a galvanized post base? It gives a method of anchorage and provides a moisture barrier! The best of both worlds!
Old 01-10-2009, 11:07 PM   #3
Registered User
Termite's Avatar
In order to give you an idea of what will work for anchorage then I need to know what the post is doing. Is it an addition, an exterior wall, is the wall sheathing attached to the post, or what? My concern is uplift, and whether or not uplift of that portion of the structure is a concern.
If uplift is not a concern and you're just trying to give it some lateral prevention, use a piece of threaded rod drilled and epoxied into the floor below and drill a corresponding hole into the bottom of the post to fit the rod and epoxy that in.
Tapcons at an angle will not do anything for you from a structural standpoint.
The best answer to your question is to use a nice thick post base to secure the post. They can be powder coated or painted any color you wish. A custom one could be fabricated and mortised into the side/bottom of the post so it doesn't protrude from the sides.
Old 01-11-2009, 09:58 AM   #4
Home Remodeler
Rewards Points: 164
If this is going to be load bearing it should have a footing, not just sitting on the slab.
mikey48 is offline   Reply With Quote
Faux Wood Beams JudyFaye Building & Construction 2 06-08-2012 04:05 PM
Adding supports for beams and joists pinkertonpv General DIY Discussions 2 08-13-2008 02:04 PM
Structural integrity of fir 6x6 beams ashen Building & Construction 8 07-31-2008 06:31 PM
how to jack my old house with old beams philmyster Carpentry 1 06-26-2008 08:55 PM
Inexpensive paintable pergola beams? dbosso Building & Construction 1 12-30-2007 09:14 PM
