Fastening Steel Stud Track To Concrete Basement Floor - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 11:04 PM   #16
urethane construction adhesive
will work nicely to hold down your new plate. I have been a carpenter for 35 years and if you want a moisture barrier between your bottom plate... metal or wood you can cut a piece of felt paper to fit under the plate. Actually you cannot even use galvanized anchors of any kind with the new treated. The galvanized metal track will be okay as it will outlast the rest of the metal track that is already there. Make it easy on yourself. hold your drywall 1/2" off the floor to avoid the drywall getting damp . Good luck !
willfinish is offline   Reply With Quote
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Filling trenches in concrete basement floor chinaclipper Flooring 7 09-08-2010 08:27 AM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 07:31 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
cutting a concrete basement floor Rembrandt Introductions 1 10-23-2005 12:58 PM
