Fastening A Recessed Bath Tub To Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2008, 03:54 PM   #1
Rewards Points: 1,062
Question
fastening a recessed bath tub to studs
the American Standard instructions say that the curled edges should be fastened to the studs and either drywall screws or roofing nails should be used. also the instructions say that because the nail/screw head will present a bump relative to the stud, a shim should be placed above it to make it even.
Q1: what would be a good shimming material that is thin enough ?
Q2: i am putting cement board over the walls. should i be using roofing nails or drywall screws or something else ?
thanks,
- a -
Old 06-14-2008, 08:28 PM   #2
remodeling pro
Predrill through the fiberglass/acrylic lip and use hot dipped roofing nails, driving them just snug to the lip. I don't know why you have to shim "for the bump of the nail head". The thickness of the nail is nothing compared to the 1/4" lip of the tub unit. The two options are to stop the cement board at the top of the lip, then just fill in that little hollow spot behind the bottom 1/2" of the tile when you set it. or relieve the back of the cement board with a diamond blade so that it can fit over the thickness of the lip and nail tight to the studs. Either 2" hot galvanized roofing nails or the screws sold for cement board application will work ok. If you have finished walls on the back sides of the studs you are fastening to, I'd use the screws, as they offer a lot less chance of creating nail pops in the existing finish than banging all those nail in. I always run a small bead of silicone to seal the joint between the tub and the bottom of the backer board befor installing the finish. It is a cheap backup to stop moisture from wicking up the back side of the backer board. Keep the bottom row of tiles spaced 1/16" (wooden match sticks make perfect spacers for this) above the tub and caulk this joint, as grout will not last in the joint when the tub flexes.
troubleseeker is offline   Reply With Quote
Old 06-14-2008, 09:48 PM   #3
Custom Cabinet Maker
cedar shakes, construction adhesive,predrill OVERSIZED pilots in the glass,screw it in with SS screws or exterior deck screws DO NOT USE DRYWALL SCREWS
skymaster is offline   Reply With Quote
recessed bath tub framing amakarevic Building & Construction 1 06-03-2008 10:11 AM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
