Fastening A Header Where Access Is Tight - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 11:26 AM   #1
RDS
Rewards Points: 150
Fastening a header where access is tight
I'm removing one stud from a load-bearing wall to make a small broom closet off my kitchen. I will of course have to put in a header resting on jack studs. My question is: how do I end-nail the header in place if, at one end, the king stud butts right up against an exterior wall? I can't get my nailer or even a hammer in there.
What are the approved/favored methods for dealing with this? I can think of a few but am wondering what experienced people think is best. I've done only a bit of framing in the past.
I realize I could take out both king studs, plus the one in between, build the new wall section and then raise the whole thing into place, but that would require a temporary wall which I'm hoping to avoid since I don't want to mark up the ceiling. But if that's the only/best way then I will.
If it matters, yes, I got a permit for this. (It's part of a larger remodel.)
Thanks in advance.
RDS is offline   Reply With Quote
Old 03-11-2011, 11:44 AM   #2
Remodeler
Rewards Points: 330
Toe nail it or drive a few screws on an angle, throw some adhesive in if it worries you but it isn't going anywhere. The weight is bearing down from the top and it is setting on the jack studs. All the nails really do is hold it in place.
iamrfixit is offline   Reply With Quote
Old 03-12-2011, 11:33 AM   #3
Framing Contractor
Thanks in advance.
Toenail it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-14-2011, 08:20 AM   #4
RDS
Rewards Points: 150
Thanks. I was totally overthinking this.
Support for Header Shakemsam Building & Construction 4 12-04-2010 03:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 08:50 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
