Old 01-26-2012, 10:37 AM   #1
Fastening Aluminum Soffits
If one was going to use aluminum soffit panels to put a ceiling on a structure (like a carport) with steel I-beams (W section) spaced across the structure, how would one go about attaching the soffit panels to the I-beams?
TIA!
huesmann is offline   Reply With Quote
Old 01-26-2012, 10:44 AM   #2
Exterior Construction
Windows on Wash's Avatar
Best to put up a set of purlins that can more easily be screwed into to span the distance across the beams.
This will level the surface as well as give you a nail/screw base.
Attaching soffit to a steel beam is painful to say the least.
Old 01-26-2012, 10:56 AM   #3
And do the purlins need to span the space between beams, or just a short distance across each beam? How would the purlins themselves be fastened to the beams?
Old 01-26-2012, 11:29 AM   #4
You are ultimately going to have to fasten the purlins to the beams.
You should have them span the full length and see if you can use plastic or some sort of pressure treated lumber where it meets the steel.
Old 01-26-2012, 11:37 AM   #5
What kind of spacing should be used for purlins?
Old 01-26-2012, 04:15 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
typically 16" o.c running perpindicular to the direction of the soffit so you have a constant fastening base to screw the soffit to
woodworkbykirk is offline   Reply With Quote
Old 01-26-2012, 05:32 PM   #7
Can you posts pics of what you have and what you want to do?
mae-ling is offline   Reply With Quote
painting aluminum soffits cjc Painting 1 11-04-2011 03:25 PM
Drilling holes to vent soffits? jessc Roofing 14 03-29-2011 09:38 AM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 12:19 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
