Fasteners For Squeaky Floors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 03:56 PM   #1
Wolf
Fasteners for Squeaky Floors
My 30-year old split-level home has upper level floors made of two 3/4" plywood layers laid down on 2x4 constructed joists 24" on center. I suspect that no adhesive was used between the joist and first flooring layer. In the last year, we added two parallel steel beams in the basement to stiffen and level the 24' span so that we can install engineered hardwood flooring that has been 'acclimating' in the house for over a year, much to the growing discontentment of my wife.
However, the floor still has a lot of squeaks which I want to eliminate before putting down the engineered wood. I'm prepared to use as many screws or nails as needed once the existing carpet is removed. Initially, I considered using 3" screws along the length of the joist. Then I wondered if 1 1/2" screws in the areas between joists would be of value. I recently read that spiral shaft and ring shank nails have excellent long-term holding power. I would appreciate advice that anyone can offer about the type of fasteners to use, pattern of application, etc. I cannot access the joists from the basement . Thanks in advance for answers.
ralphfravel is offline   Reply With Quote
Old 10-16-2009, 04:02 PM   #2
Registered User
Rewards Points: 4,910
The glue is what stiffens two deck layers and stops squeaks... That said, I had good results with the spiral shank nails - 2-3/8" long for the nailgun. I framed new houses for 10 years with them and only two call-backs.This was with one layer of 3/4" sub-floor decking, not two. And you have to hit the joists to do any good. But screws do a superb job yet are expensive. They would be better for the field application. The ring shank from a nail gun tend the blast the material from the sides of their hole when going in, is the main reason I don't use them. The spiral shank (2-3/8") turn 1-1/2 times going in and coming out.A longer nail for the application on the joist and screws in the field would be my choice.
Be safe, Gary
Old 10-18-2009, 06:53 PM   #3
Wolf
Thanks GBR for your input. I appreciate you taking the time to respond and have come to value your input on many other posts as well as my own.
Cheers.
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 06:59 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
