Fascia And Soffit Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 09:20 AM   #1
Question
fascia and soffit question
I have new home construction underway. My builder needs to know within days on our decision on materials to use for soffit and fascia under the edge of the roof. The house is two story stucco with a barrel tile composite roof.
Vinyl is out, wood is long term painting/maintenance, stucco is too rough (would attract wasps and bugs). So, what is available except aluminum fascia and hearty (or some kind of concrete) type soffit. After the exterior crown (some made of stucco and some of wood type crown), there is about 12" of soffit area to cover. What are the options (with pros and cons)?
Andrew Carter is offline   Reply With Quote
Old 12-01-2010, 09:26 AM   #2
the Musigician
DangerMouse's Avatar
Hi Andrew, welcome to the forum.
What is your location? If you have carpenter bees as we do here, I'd go with the aluminum fascia and soffits.
I used aluminum fascia and then vinyl for the soffits myself, why is it not good for you?
DM
Old 12-01-2010, 11:25 AM   #3
Seems like you've mentioned just about every option there is! What do the other houses in your area use and what does the contractor recommend?
mrgins is offline   Reply With Quote
Old 12-01-2010, 04:44 PM   #4
Registered User
Rewards Points: 5,460
With only 12" soffit depth left, that limits your venting choices. If you will be venting....
The vinyl only gets little more than 1/2 (4.68NFVA) per foot lineal. http://files.buildsite.com/dbderived...rived92755.pdf
Figure the required venting: http://www.airvent.com/homeowner/pro...it-specs.shtml
Another choice: http://www.cor-a-vent.com/PDF/S4002P.pdf
Install the continuous vent (9NFVA) next to the fascia board for best service:pp.616: http://books.google.com/books?id=Z8a...0vents&f=false
Aluminum is another, check on the NFVA= only 6-7, if I remember correctly...
Gary
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 09:01 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 10:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
