Fascia & Soffit Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2007, 08:54 AM   #1
Malibu Mike
MIKEGOUGH1's Avatar
Fascia & soffit help
I am building a garage and using trusses. I plan on using a 12" overhang of my decking on the gable ends. How do I attach the fascia? Do I need to make some type of floating rafter at the top, and if so, how do I do that? I am planning on running 2x4's connected to the ends of the rafters extended out 12" on each side with the fascia over that. I just am not sure how to attach the fascia at the peak.
MIKEGOUGH1 is offline   Reply With Quote
Old 01-20-2007, 01:29 PM   #2
Darylh's Avatar
It sounds like your laddering the gables( 2x4 2' o/c up to the peak). If so make sure you have one on each side of the peak you attach a 2x4 barge board to the 2x4 latters and then attach the facia to that. This set up also gives you a return for your soffitt work.
Darylh is offline   Reply With Quote
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 10 09-07-2016 01:21 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
