Fascia Replace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2016, 07:48 PM   #1
Rewards Points: 132
Fascia Replace
I need to replace ONE fascia board on my garage. Gutters are falling off due to rotten wood.
I like things to look nice, however, this is still just a garage, and nothing high-end or "cool" is needed. I just need to run one length of 2.5 car garage. White would be nice, but I suppose bare wood that must be painted is ok.
How should I proceed?
giddyap is offline   Reply With Quote
Old 10-04-2016, 08:05 PM   #2
Rewards Points: 13,300
Re: Fascia Replace
#1 Figure out why it rotted in the first place,
Clogged gutters?
No drip edging on the roof?
Not enough shingle over hang?
Someone let it go to long with no paint?
Any I do are just pine and I wrap them with coil stock so there's never any painting needed.
If you cheap out and go with just wood then prime and prepaint all side, most often the first place it fails is on the cut ends.
Old 10-04-2016, 08:13 PM   #3
Rewards Points: 3,426
Re: Fascia Replace
PVC comes to mind, once and done.
Canarywood1 is offline   Reply With Quote
Old 10-05-2016, 09:58 AM   #4
Rewards Points: 132
Re: Fascia Replace
Fascia just gets attached to the tail ends of the rafters, right?
Nails or screws? What kind?
Fasten to EACH rafter end?
Gutter fasteners also get screwed through fascia and into rafter ends, or anywhere on fascia?
Old 10-05-2016, 10:45 AM   #5
Re: Fascia Replace
I use Stainless steel siding nails but ring shanked 8D will work fine.
I use the Stainless so rust spots are never an issue.
You have to nail into the rafter tails the rest is just open air.
Idealy you want the gutter as high as possible and behind the drip edge.
Anyplace in the facia will be fine.
Just make sure you use enough of them.
Hidden gutter hangers look and work best.
Old 10-06-2016, 09:43 PM   #6
Rewards Points: 132
Re: Fascia Replace
Since,
1) they probably dont sell 25' fascias, and
2) i'll need to have it cut to fit in my Nissan Versa
...do two fascia ends get nailed into one rafter tail where there is a seam???
As you can see, I am a go-getter, dying to learn, but quite the newbie.
Correct Fascia Installation Rudy82 General DIY Discussions 2 07-30-2014 10:58 AM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 11:00 AM
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 07:33 PM
What type of wood is used to replace soffit and fascia board? creamaster Carpentry 6 07-16-2008 02:20 PM
