Old 08-29-2009, 01:13 PM   #1
fascia leaking all year round
We have water leaking out of the facia in two spots on our big wrap around porch. House is 100 years old. Replaced roofs 5 years ago.
Initially Husband thought it was heat transfer from second floor heated bedrooms as we noticed the ice that had formed when ice forming made the crack between the sofit and facia larger.
I thought it was from water leaking behind old flashing on porch roof and assumed it would be solved when we replaced flashing and siding. Which we did.
We were both wrong, as we have discovered that after replacing windows, flashing and apply new siding then scraping, caulking and painting all wood surfaces of the porch facia and sofit, water has continued to leak out at the same point each rain all summer??? It has been a VERY wet summer.
When roofs were replaced 5 years ago they were taken down to sheathing and ice guard was put down for the first three feet of the roof from the drip edge.
I am at a complete loss to figure out where this water is coming from.
Any suggestions would be most appreciated. We have always been do it yourself people, but this work was contracted. My husband is no longer able.
jtsy10 is offline   Reply With Quote
Old 08-29-2009, 04:55 PM   #2
1. Is it leaking in one spot of the soffit?
2. Did you pull that section to explore the water source or damage?
A picture would help.
Be safe, G
GBR in WA is offline   Reply With Quote
Old 09-01-2009, 07:59 PM   #3
General Contractor
I agree with GBR, a photo of that area would really help us see the issue. It sounds like the roof was installed correctly but without seeing your issue i cant say 100%
Deperryandassoc is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking the flashing and resealing all seams. You want to make sure that you check all of the flashing around all of the vents, the fireplace and any other protruding objects or... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The valley flashing is laid between two valley battens and fastened through the top flange. Where the valley terminates at a fascia, the valley... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Whether your family will be comfortable on your porch depends on whether you've built it at a proper level. A level porch helps furniture stay in place and keeps glasses from sliding off your table onto the ground. You need to know how to find and... Read More »
Plastic fascia and soffit panel attaching to it. 4just1don General Discussion 1 07-22-2009 10:26 PM
12" Fascia Board Maralind Roofing 6 01-26-2009 06:26 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing 5 01-06-2009 07:51 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
